What is the name of the tool??
Discussion in 'Electrical Forum discussion & Blog' started by chestnuts, Jul 19, 2008.
  1. chestnuts
    chestnuts DIY Member
    Jan 11, 2006
    An buddy of mine is an electrican and had most of his tools handed down to him. He has a tool that will twist 2+ wires together, but he has never known the exact name of the tool. You put the wires in one end and then spin the handle to twist the wires together before you put on a wire nut. Anyone know what the name of this tool is or what company makes one??
    Thank You,
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I've got 4 or 5 tools like that that are used to twist safety wire -- used in aircraft systems to prevent threaded things from becoming unthreaded things. They are called ... umm ... "safety wire twisters." I don't think they would work for electrical-wiring-sized wire.
  4. hj
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    As Mikey said, they are for safety wire.
    http://www.whizwheels.com/Tips/safetywiring.html
    Stainless steel wire is threaded through holes in the nuts or bolt heads and oriented in a way that prevents any fastener from un-screwing due to vibration as it might in missile, aircraft, or machine operations.
    The pliers are used to make it easy to twist the wires.
  6. Igor
    Igor New Member
    Dec 2, 2007
    Former Motorhome Electrician
    Oregon
    No, those are for stainless steel safety wire. The safety wire is run through holes drilled in nuts and bolts to keep them from vibrating loose.
    I don't know of anything like the OP describes that is currently on the market, but there is a patent for a wire-twisting device.
  7. jimbo
    jimbo Plumber
  8. chestnuts
    Jan 11, 2006
    Finally found what I was looking for on an auction site :rolleyes: ....
  9. Igor
    Igor New Member
    Dec 2, 2007
    Oregon
    That "Nut Twister" looks like it's meant to twist the wire nut, not twist the wires before installing the nut. There are other tools out there that will do the same thing; some Ideal screwdrivers have a wire nut wrench in the handle, and you can get wire nut bits for a cordless drill.
  10. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    I am curious as to why we need extra tools for this very basic stuff.
    I am all for more tools, but a tool to twist wire before putting on a wire nut?????? :rolleyes: It's called a lineman's pliers.
  11. hj
    tools
    Some people have too much empty space in their tool boxes and want all the specialized tools they can find. A lot of times all you need is the multipurpose hammer/screwdriver and a screwdriver/chisel, possibly a pliers/hammer, and you can accomplish a lot.
  12. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Build it and they'll buy it!
    Here we have the hammer/pliers!
    [​IMG]
  13. chestnuts
    Jan 11, 2006
    The Reason for the specialty tool.....
    The reason a specialty tool is needed is because I am trying to twist 4 wires together. The reason I am doing that?? Because of the idiots that wired my garage before I bought my house. I had an outlet quit working. When I went to replace the outlet I found one hot into the outlet itself, then 3 hot wires from the the back of the outlet to 3 light switches. This ended up buring up the outlet, so I am told. So, now what I am trying to do is bring the hot into the outlet box, then jumper to the outlet and the other 3 switches. To do this, I have to twist 3-4 wires together. I watched my buddy twist nuts on 4 wires quickly when we remodeled my kitchen. So, I was looking for a "PROFESSIONAL" way to accomplish this.
    Now, what is SO wrong with that????? :confused:
  14. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Here's a better way
    While you can twist 4 wires together, with or without special tools, they now make push-in junction gizmos that are a heck of a lot easier to use and take less space in the box. Downside is they're a one-way trip -- you can't change your mind after the junction(s) are made. Made by Ideal and others, they're available in big-box stores and trade outlets. Come in several sizes:
  15. Wrex
    Wrex Member
    Mar 19, 2008
    New Jersey
    Oooh pretty colors :D.
    They look nice but they aren't as compact as 4 wires and a wire nut. This is very important when space is at a premium.
    I've personally never been sold on the "clip in" design I still use the screw on fasteners on recepticles.
    On a related note recently I just installed a GFCI outdoors and it had a wonderful compromise. You insert the wire through the hole in the rear then tighten the screw on the side the screw pulls a fastening plate tight onto the wire "biting in" and holding it in place.
    Now thats a good idea I want to see that on ordinary non-GFCI recepticles.
    Whats the big deal about twisting 4 wires together?
    As long as you have linesmans pliers and not thin nose pliers you should be able to do it fine.
  16. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    They're called "back-wired" receptacles and are commonly available. Look for "specification grade" on the box. They cost more than the cheap ones but they are better made all around.
  17. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    The wire nuts you're using must be a lot smaller than the ones I'm using...
  18. Wrex
    Wrex Member
    Mar 19, 2008
    New Jersey
    Ah specification grade so thats what that mean't on the package.
    I never quite trusted the old "click in" mechanism but now that its fastened down with a screw I feel much more comfortable using them.
    I was just going by the picture without looking at actual dimensions from the pics. Not a good practice.
    These push in connectors remind me of butt connectors introduced for phone lines years back. The phone line butt connectors all worked fine when installed but years later they introduced all kinds of problems.
    The real question is what is their longevity?
    A release for the wires would have been a good idea. If someone wanted to run another line into the box they would have to cut off all of the wires. If this happened too many times you would end up with short wires that don't reach.
    I am naturally suspicious of new products until they have been proven in the field.
  19. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    Speck grade is the only kind I use any more. I still check the outlet in the box to make sure they are the kind I like! I just dont trust the big box stores! And I have used them to join 4 wires together and they work nice. NOW if they would only make the ground wire like that! I know I know probably some NEC or UL rule.
  20. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Good question. These looked too much like "backstabbed" receptacles for me, but these are good for 12AWG, are really quick to install, and do save a lot of space. The clincher was when a bunch of Halo can lights I bought came with these things already pushed on to the fixture pigtails. I love them.
    That probably would have made them more expensive, and perhaps added an uncertainty that UL wouldn't have liked. Unless I'm certain of a box's final configuration, I use these thingies with an extra hole or two for later mods.
    Me too. I'll let you know if I have any problems.
  21. Tundra
    Tundra New Member
    May 29, 2008
    Homer Simpson (hydro though)
    Yellowknife, NT
    If you do any work on barbed wire fences you will appreciatte these to say the least!!! Just ask a good ole' farm boy :D
    Tundra
Similar Threads: name tool
Electrical Forum discussion & Blog Name that gear game.. Jun 6, 2014
Electrical Forum discussion & Blog Use of registered names like ROMEX® on this forum, this is a poll Dec 7, 2011
Electrical Forum discussion & Blog New Wire Stripper Tool Aug 28, 2016
Electrical Forum discussion & Blog GFCI on wet power tools..... Jan 27, 2012
Electrical Forum discussion & Blog Electrician starter kit with toolbelt Dec 4, 2008
