What do I use to reduce water pressure to Steam generator
Discussion in 'Shower & Bathtub Forum & Blog' started by CountryBumkin, Sep 5, 2009.
  1. CountryBumkin
    CountryBumkin Active Member
    Sep 4, 2009
    Orlando, FL
    I am remodeling my bathroom and converting my shower to a Steam Shower. I was planning to use a Mr. Steam MS-400E generator. I noticed in the installation manual that they require the water pressure to be reduced to 15-20 psi. My water pressure is currently 60 psi. I'm on a well.
    What device do I use to reduce the pressure? Preferably something small enough to fit in the cabinet (under vanity) which will house the generator.
    And is this a good idea, or should i look for another brand generator that can run on full pressure?
    I looked at Amerec generators but they don't have the controls in the finish that match my fixtures - but more interestingly, they want the water PH at 10.5 to 11.5 (Mr. Steam doesn't specify). My tap water is closer to 7.2 PH. Is 10.5+ reasonable?
    Thanks again.
  2. CountryBumkin
    Sep 4, 2009
    Orlando, FL
    I searched Goggle for an hour at least looking for a water regulator valve that reduced pressure to a 20psi working range and was about to give up (everything seemed to be aimed at reducing pressures to the 50-75psi range) when I found what I was looking for. Ironically, it was a link from the (this) Terry Love website to series of plumbing supplies. The solution is a Watts model 123LP valve.
    I gotta find that link again and save it as a favorite.
  4. hj
    steam generator
    They may LIKE a 15-20 psig into the water line, but I have always connected them directly to the water system.
  5. CountryBumkin
    Sep 4, 2009
    Orlando, FL
    It's good to know they can handle the pressure.
  6. hj
    pressure
    There are very few plumbing items, especially valves, which are NOT rated up to 150 psi working pressure.
Similar Threads: reduce water
Shower & Bathtub Forum & Blog Hot water reduced to trickle in shower - cold water works fine Jun 24, 2014
Shower & Bathtub Forum & Blog Reduced water pressure to shower Oct 4, 2006
Shower & Bathtub Forum & Blog reduce size of cutout in cultured marble shower to match new valve trim plate gasket Apr 19, 2012
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
