What do I need to straighten the floors?
Discussion in 'Remodel Forum & Blog' started by smhowell, May 3, 2005.
  1. smhowell
    smhowell New Member
    Apr 2, 2005
    Oklahoma
    My husband and I are planning a complete remodel of a 1939 house with a crawl space. We know that there is a severe sag in the middle two rooms of the house, and buckling in the floor in the latest addition (circa 1960). Before we start moving walls, we want to straighten the floors using hydraulic or house jacks. (I have been told that straightening the floors won't cost much more than labor, but leveling the floors will cost bunches.) We have been told that we need to plot the floorplan (I have already drafted the floorplan in scale) and determine where the high and low spots are. My husband wants to use a laser level to determine the height of the floor in various places. My question is: what laser levels (type, brand, model and price range) do people recommend? Which ones should we avoid?
    Any additional thoughts on floor leveling or straightening would be appreciated.
    Thanks in advance,
    Sharon
  2. jadnashua
    Dips can be caused by joists that were cut to let plumbing, air ducts, etc. through. If not done properly, that can severely weaken a joist and make it sag. You'll need to reinforce those areas. If you jack things up, do it slowly otherwise you'll end up cracking all sorts of things. It is very possible that the footings consist of a board layed flat on the ground or a stack of stones. Get some expert help or at least advice. My guess is that it should be on-site. My unprofessional opinion.
Similar Threads: need straighten
Remodel Forum & Blog Garage rebuild need help Nov 5, 2016
Remodel Forum & Blog Do I need to retrofit my pony wall retrofit? Jun 6, 2016
Remodel Forum & Blog Basement closet wall with foam needs drywall for fireproof? Jun 4, 2016
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog Need some guidance on making a fence design a reality Jun 15, 2015
