jjinatx
I have a 22 year old well trol 80 gallon tank on my rainwater system. It's been connected to a few different shallow well pumps over the years. Over the last 10 years or so, I've had to drain the tank and re pressurize it 3 times because the pump was short cycling. The tank is not leaking water. This last time I re pressurized it, I replaced the schraeder valve and added a metal cap with a rubber seal in case the problem is a very very slight air leak.
Is it normal to have to re pressurize a bladder tank every so often?
