Well with both hand pump and compressor?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by 42piebabelfish, Jul 14, 2009.
  1. 42piebabelfish
    42piebabelfish New Member
    Jul 13, 2009
    I recently had a 4 inch diameter well dug, and hit water 32 feet below ground. We hope to use it to provide water to the house, using both a compressor and a hand pump.
    However, the well diggers stated that it is impossible to have both on the same well. We want to have both so that we can have continue to have access to safe water during power outages and disasters such as hurricanes.
    The compressor line is apparently going to be 1 inch in diameter.
    Are the diggers correct, or is there a way to have both on the same well?
    Thanks for any help you can give.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If the air lift line is 1" and the hand pump line is 2", they should both fit inside of 4" casing.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    This compressor thing is new to me. Can you tell me how it works? Does it pressurize a tank somehow?
    What kind of hand pump? Deep well or a Pitcher pump?
Similar Threads: both hand
Pumps and Tanks Well Forum & Blog. Water is life. CSV Question - Best of Both Worlds Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. A BAD PUMP,A BAD CONTROL BOX OR BOTH? May 30, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch contacts closed, power both sides, pump not running May 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. New 1HP well pump: Do I need a Control Box with both RUN and START capacitors ? Dec 19, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Remote pressure tank or pump or both? Sep 1, 2011
