Well Testing
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Budster, Mar 7, 2006.
  1. Budster
    Budster New Member
    Sep 4, 2005
    What is the proper way to flow test a well? My in-laws are refinancing and their bank is requiring a flow test on their well. They just had the jet pump and all of the lines replaced last fall. During the servicing the depth of the well was not checked but the end of the line was down 125 feet and it had a good 80 feet of water above it. Now their plumber is saying he has to re-dig up the well, disconnect the pump and pull all of the lines to do a proper flow test. Shouldn't this have been done when the well was serviced?
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Do It Yourself Flow Test
    "Their plumber?" Sounds like you are getting hosed.
    First, find out what the bank requirements are. What do you have to prove? Gallons per day? Gallons per minute for how many hours? Find the minimum flow that will satisfy them. You don't really need to know what the well will do if it has more capacity than required.
    When you get the requirements, here is a do-it-yourself flow test.
    1. Connect a garden hose to your system at some convenient place.
    2. Turn off all water uses in the house.
    3. Open the faucet to the hose until the pump comes on.
    4. Adjust the faucet until the hose flow balances pump capacity, which you will know when the pump manages to hold a constant pressure between on and off pressure switch settings.
    5. Measure the gallons per minute (water meter (best); or a bucket and a watch with a sweep second hand) and let it pump until you meet the requirements. You may have to shut it off from time to time if the pump capacity exceeds the well capacity.
    6. Keep track of the time that it is pumping. You could connect an old 115 Volt electric clock to the circuit to record the time.
    Another way is to let the pump cycle on and off, and determine the amount of water per minute or hour of actual pump running time. Then put a clock on the pump and run enough water to show that you meet their requirements.
    A water meter can be had for about $50 from USA BlueBook (Phone 800-548-1234; Stock number 62276, $31 + shipping and they accept credit cards).
  4. Budster
    Budster New Member
    Sep 4, 2005
    Thanks Bob. This is what I suspected. I'd be interested in getting feedback from others as well, Thanks again.
  5. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I fully agree, your getting the wrong info.
    If you have your pump in a place where you can just cut the mail line feeding the tank and then pipe to a 5 gallon bucket, you can simply measure the time required to fill the bucket. That will tell how much the pump is getting. This should be done after the pump has ran for at least 10 minutes to give the pump and well time to equalize. Once the pressure gauge shows a steady pressure, do the test. This will be the actual amount of water the jet pump can get from the well.
    Then get a mop to clean up the basement.
    bob...
Similar Threads: Testing
Pumps and Tanks Well Forum & Blog testing 3 wire pump Mar 30, 2015
Pumps and Tanks Well Forum & Blog Seeking recommendation for a good water testing lab Apr 11, 2014
Pumps and Tanks Well Forum & Blog Testing Pressure Tank Apr 18, 2013
Pumps and Tanks Well Forum & Blog WX202 Pressure Tank testing question Apr 11, 2011
Pumps and Tanks Well Forum & Blog pressure testing well casing Mar 7, 2011
