Well Tank Connction Leak Advice
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Beem, Oct 24, 2004.
  1. Beem
    Beem New Member
    Oct 24, 2004
    Just installed our well's pressure water tank and seem to have a dripping leak where the fabricated brass tee (copper pipe with brass fitting) joins to the steel female elbow on the bottom of the tank.
    Installed the fitting with about 3 wraps of 3/4" teflon tape. The brass fitting is just about all the way in with one thread showing.
    I had made up and taken the joint apart a couple of time before final assembly due to varying advice on hor to treat the threads. Apparently the one I followed didn't work.
    Since the brass fitting is almost all the way in, should I try to use it again with pipe dope, or tape and dope? Or buy a new tee?
    Could the brass fitting have been distorted by multiple tightenings? It doesn't seem possible that the steel fitting would be affected by the brass.
    Any advice would be appreciated.
  2. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    Sometimes these fittings need approx 6 or 7 wraps of teflon tape to seal properly. Another fitting may also do the trick
  4. Beem
    Beem New Member
    Oct 24, 2004
    7 wraps of teflon did the trick.
    Funny how opinions vary....some said 2 wraps max; obviously the simple things need more specific attention.
Similar Threads: Tank Connction
Plumbing Forum, Professional & DIY Advice Tank not filling after flush Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Low well press. + empty press. tank? Just moved in :( Jan 27, 2017
Plumbing Forum, Professional & DIY Advice Tankless PVC Venting Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Pressure Tank Location Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Disinfect new water pressure tank? Jan 8, 2017
