Well Tank Casing Repair - Hole
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by robertpatterson, Jun 17, 2009.
  1. robertpatterson
    robertpatterson New Member
    Jun 10, 2009
    I have a hole in my Residential Well Tank Casing. How do I fix it? Or do I need a new tank?
    Any recommendations would be a great help.
    I believe it is a steel 10000 gal tank.
    Thanks.
  2. upper
    upper DIY Senior Member
    May 30, 2009
    Fresno, CA
    Is that a big tank,or am i missing something...Upper
  4. Teets
    Teets CT pump guy
    Aug 23, 2007
    well tech
    Watertown, Connecticut
    Is it a tank for a low producing well, for multiple wells,or is it for residential storage. If it's an atmospheric tank with a booster tank/booster pump you may be able to repair it, if it's just atmospheric pressure. If it's a pressure tank I wouldn't recommend it as that involves an air charge that constantly gets compressed and I wouldn't recommend a repair that's constantly under higher pressure
  5. robertpatterson
    Jun 10, 2009
    It is a residental storage tank with a pressure pump next to it. The holes range from pin to pea size.
  6. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Can you give me a reason why it's so large? Do you have water trucked in?
  7. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    With an old steel tank you can drive wooden pegs into the holes. They swell up and seal nicely. I have seen tanks with a hundred wooden pegs. You would be surprised how long this temporary patch lasted.
  8. robertpatterson
    Jun 10, 2009
    Thanks, will try the wood pegs today. I stuck magnets on the holes- some work and some have drizzles. I am looking for a temp solution until the summer when I have to water lots and then can empty the tank and reseal it.
    Any tips on resealing it?
    It is a 10,000 gal tank. Use it for the house, pool and lots of watering of groundcover.
    Really appreciate all the help.
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
    When you start patching an old steel tank, there is no place to stop. I would replace it with a plastic one. You can probably get by with a much smaller one. While it is still working, do a little testing on the quantity used and time to refill and decide how large of tank you really need.
  10. robertpatterson
    Jun 10, 2009
    The tank got drained- Gardner left some sprinkers open. So now would be the time to fix the holes. The wood pegs worked! Thanks. But now the bottom of the tank is leaking. One small area. How would I fix this? Someone was going to line it with the same material that seals pipes but he was told today that the stuff is toxic.
    I believe I need a new pump so before getting a new tank, I want to see if my water is low or the new pump works. Rightnow, I get very little water..I think that is why I have such a big tank. I'm the third owner of this house.
    Thanks for all the help!
  11. robertpatterson
    Jun 10, 2009
    I cook with it, but I don't have to. Make Tea & Coffee, but don't drink it plain. I water the fruit trees and plants with it also.
Similar Threads: Tank Casing
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank in casing? Jan 23, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
