Well system I am inheriting with house
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by pitterpat, Dec 28, 2011.
  1. pitterpat
    pitterpat HandyWOMAN
    Jun 25, 2005
    A HandyWOMAN service..."Why hire a handyman when y
    Indianapolis
    Attached are pictures of a well system I am inheriting with a house I am buying in Indianapolis, IN. It is the original system from when the house was built in 1956, bladderless tank and well pump (Duro 3.5 GPM). The well is thought to be not very deep. I know that I should go on city water but financially now it is not good for me to do. The switch on the pump does not work all the time. What upgrades do you suggest? IMG_4328.jpg IMG_4327.jpg IMG_4329.jpg IMG_4330.jpg IMG_4331.jpg IMG_4328.jpg IMG_4327.jpg IMG_4329.jpg
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    A new switch would probably run you around $20.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    If thats original 1956, then you got a charm. Wait till it breaks and then replace it with parts that will last about 8 years today.
  5. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    That is an old system! But if it works what the Hey! The Schrader (tire) valve on the is to ocassionally add air to the tank if it becomes water logged. To add air you will need to turn off the power to the pump. Then drain the tank down at the lower faucet on the bottom of the tank, while adding air to the top until you get air from the bottom tank faucet. Then close all faucets and turn the pump on. The pump will probably run a while while filling the tank. If the pump loses prime I suspect that the diaphram in the air volume control has a leak. Replace the AVC or just plug the small line that goes from the tank to the pump. When it works it's supposed to inject a little air in the tank each time the pump starts.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If you haven't bought the house yet you might want to check into the availability/legalities of the city water connection.
    Where I live, a house cannot be sold without being connected to the utilities that are available at the location.
    It is the seller's responsibility to have the connections made prior to sale.
    Another possibility would be to negotiate with the seller to pay for part or all of the connection costs. If the existing well has problems, it could cost you 10 grand or more for a new one.
  7. pitterpat
    Jun 25, 2005
    Indianapolis
    Not the case in Indianapolis, does not have to be hooked up to city water, just sewer. The seller is not paying the connection cost, they are not budging, to hook up to city water is about 5K here.
  8. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    You probably have better water than Indy can provide, From the Lake.
    Here around Houston, They calculate the sewer FEE on water usage. How do they do it in Indy ?
  9. pitterpat
    Jun 25, 2005
    Indianapolis
    What I found is that they estimate the type of waste and the volume and bill you. This is base on "analysis and volume of similar installations".
Similar Threads: system inheriting
Pumps and Tanks Well Forum & Blog. Water is life. Short cycling issue. Unsure if system is even set up correctly! Feb 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. New Well, Need Advice on Systems Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Low water pressure on well system Jan 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Replacing existing well pump system Jan 8, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water System and Cistern Questions Dec 10, 2016
