well pump problem
Jason Turner
NC
i just bought a house that had been winterized. after turning on power to the well and check that all valves are open i am having a problem
i have great pressure at the spicket between the pump and the tank
pump cycles on and runs until pressure is built and the pump remains off until a valve is turned on however the pressure at the house is low enough to stop with a little force using your thumb. i have taken the piping loose at the last valve in the line before entering house and the results are the same
i can't understand why i have outstanding pressure at the well but not at the house
am i missing a flow control valve or something done to the well system when it was winterized
please help
thanks in advance
Bob NH
New Hampshire
Check for a leak between the tank and the point where it enters the house. If there is no flow, the pressure should be the same throughout the system.
This is a time for pressure gauges at both ends that you can check with and without flow.
