abeljda
Hello, I have a shallow well pump its a model 5srp3c 1/2 hp jacuzzi. I replaced the same model 5 years ago so its a fairly new pump. I replaced the draw line from the pump/housing to the systren/well 3 years ago as i had a cracked line. replaced the foot valve, all piping everything. has worked Ok since but the other day I was walking by the housing and the pump was running and no one else was home and I knew there was no water running which is always bad. I spent the day trying to get it to work. I replaced the pressure switch, I took off the little line from the pressure switch to the pump and blew it clean it was fine, took out the venturi inspected and it seemed fine, the pressure tank was fine holding air with the right psi, so i figure it had to be something wrong with the foot valve so I went thru going down in the well to get it and replaced it. it still seems to not want to shut off at the 30/50 setting on the cut out side, I have been able to reduce the pressure a bit to get it to shut off but did not really want to do that but it worked fine for a few weeks. Then a couple weeks later, same thing walking by the pump house I heard the pump running when it shouldnt. I went down in there set the pressure down a bit more and again its working. Wondering if anyone has any ideas outside of what I have done, it is going to burn that pump up enventually I believe.
