Mikebarone
DIY Senior Member
My parents are on a community well along with three other families. The well has a 5 horse power pump that is down around 600 feet. They do not have a storage tank and a jet pump; it just pumps against 4 bladder tanks and then out to the homes.
The pump has been bring up sand and silt for some time, and it is now tripping the main 30 amp breaker. I took amp meter reading just below the breaker, (when it was popping about twice a day), and I was getting 31 to 33 amps during a cycle, (that is set at 30/50).
I called some pump companies in the area, and some suggest that the problem might be a bad run capacitor, but they are almost sure, (because of the sand and silt it has been bringing up for quite some time) that the pump is bad.
If the pump is bad, would it be a good idea to get a smaller replacement pump, and install a storage tank and jet pump? In getting a smaller, less volume pump, I would think it may cause less turbulences, and there fore sucking less sand and silt through the pump.
Thanks much,
Mike
Thanks much,
Mike
