Well Pump and Water Problem
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by claywallace, Oct 18, 2012.
  1. claywallace
    claywallace New Member
    Oct 18, 2012
    Tennessee
    I have lived in my house for about a year and untill recently ave had no problems out of the well. But a few days ago my water got dirty. I assumed I just needed to change the filter, and planned to pick one up next time I was by the hardware store. But in the meantime I noticed that not only did the water get dirtier but it also got hot. I was able to take a shower with just the cold water on. That completely confused me but I decided to go ahead and change the filter. So when I went to change the filter I turned off the pump at the breaker box, replaced the filter, then turned the breaker back on...but the pump wont start. So im guessing the pump is burned up now?
    Also I have a very shallow well, as does everyone on my road, about 50 feet or so, and I can see water in the well. So I know its not completly dry at least.
    Any suggestions or comments would be greatly appreciated. Thanks
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I think you have a hole in the drop pipe down the well. It recirculates water in the well until it gets warm. If it runs until the water gets hot, it will burn the motor and melt the pump. If you have PVC well casing, it might have colapsed and grapped your pump/motor. Hope it comes out for you when you start pulling up.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Ja, I think valveman nailed it. At least it's only a 50 foot well if you lost it and need to drill a new one. Drillers probably charge less down that way. Around here it would cost me $48 per foot so I'd be out of pocket at least $3000.
  5. claywallace
    Oct 18, 2012
    Tennessee
    Someone told me that the well may be collapesed but I can see water so thats not right...right?
  6. claywallace
    Oct 18, 2012
    Tennessee
    So I guess tomorrow I should cut the pipe and pull the pump up? Im sure ill have to replace the pump, but if there is no holes in the pipe then what else could be the problem? Can the ground water table shift, like maybe it shifted upward and the pump was now at the very bottom? Would sucking up alot of mud cause my water to be hot?
    Im new to wells and need advice. Thanks
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    The only scenario that could produce enough hot water for a shower is what valveman described.
  8. claywallace
    Oct 18, 2012
    Tennessee
    I think that maybe my pump isnt cutting off, and it's just deadheading down in the bottom of the well. Could that have an impact?
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
    A deadheaded pump won't run long enough to get the water hot. The pump would melt down in about 5 minutes.
  10. claywallace
    Oct 18, 2012
    Tennessee
    Well I pulled the pump today, and sure enough, the pipe had a big crack in it right before the pump. got it all pout back together and everythiong seems to be running good. The water is not warm anymore and the pressure is holding good. But it is still dingy. How long should I expect it to take for the water to settle out? Thanks for all the help guys.
Similar Threads: Pump Water
Pumps and Tanks Well Forum & Blog. Water is life. Water pump stopped. Short cycles then stops. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Stand Alone Water Tank & Pump: Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Power for water treatment injection pump Nov 9, 2016
Pumps and Tanks Well Forum & Blog. Water is life. 1/2hp water jet pump struggles w low water levels Oct 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Problems pumping lake water to cottage Aug 23, 2016
