Rotaris
If its not broke, fix it until it is!
Yes the pressure goes to 60psi.
I had the expansion tank set at 40psi for 5 years, it just always banged and creaked at lowered pressure in the line. So I though it should be set a little higher, that is when the brain damage started!
I thought by setting the expansion tank to 59psi it would get rid of this, which it did. Except now the pressure climbs to like 70 after using hot water. I just can not comprehend why?
The expansion tank should be taking excess pressure. Not going above ???????
