Watts - Quick-Connect
mmcgady
I am finishing my basement. I have rough in drainage for a full bath. I need to cut into the existing water supply for shower, toilet and sink. The whole house is currently supplied with Pex lines. I want to "tie in" to the Pex with Watts Quick-Connect fittings and continue with Pex for the new bathroom.
What is the "word" on these Quick-Connect fittings? Any problems?
Master Plumber Mark
www.weilhammerplumbing.com
shark bite fittings
if they are like the "shark bite" press on push together
fittings they are probably pretty good....
sort of a universal fitting that will tie together copper, pex, cpvc
ect.......
we have had real good luck with those and I would guess that
they are about the same....
they are very good time savers in combat situatioins....
mmcgady
Why would a plumber not use them for the whole house? The crimp tool is over $100. Does the savings in crimp fittings over quick-connect pay for the tool in the long run?
Cass
The cost of the fittings would be to high to do a whole house with, a 1/2" T was $7.00 last I checked. You could get to $100.00 real quick at thoes prices.
With the tool you could sell it after using it and recoup some / most of the cost.
Master Plumber Mark
price is always why...
these fittings are GREAT for COMBAT......
On satruday i installed a waer heater in a nasty old cellar
and it had the old cpvc 1/2 plastic comming down to it....
I made up two copper nipples to female adapters
and simply put two of those
quick connect shark bite fittings in the line and got the heck out
of there fast.......
they are time savers in bad situations.....
On a new house it could cost you upwards of $300 or more
to run the place out of them
they are really not for a whole house situatioin when things
are fairly easy and smooth and you got a employees you are paying
to do the plumbing
and 300 bucks basically pays most of one dummies salary
