Water supply line along outside wall
Discussion in 'Shower & Bathtub Forum & Blog' started by Bronson, May 5, 2007.
  1. Bronson
    Bronson New Member
    May 5, 2007
    Consultant
    Northern Virginia
    Hoping for some advice regarding a shower remodel. Planning to take out a bump out, pulling out the 48" shower pan and laying mosaic tile for a 60" shower. No venting or piping found in bump out, just a void, so I didn't think it would be a problem to lengthen the shower. One contractor claims I must relocate plumbing to the inside wall since I will no long have the void providing some protection from the outside wall. Another contractor claims its not a problem, that they will add another inch of insulation to protect the water supply line, but the shower head can remain on the same wall as it is currently. I'm in the mid-atlantic, where cold weather is not much of a problem, but is it typically advisable not to place shower plumbing lines against an outside wall? Or can additional insulation provide a solid fix?
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    closed cell foam has the highest R value per inch. A sheet of that will block cold (and air flow too). Also blocks heat. You must have room for 1/2" or even 1".
    david
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I would think it best to not have plumbing in an outside wall. Even if it did not freeze, it would still be subject to greater temperature changes than found in an inside wall, and that might lead to condensation running down the pipe and/or to hot water taking longer to arrive.
Similar Threads: Water supply
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Delay with hot water supply in shower Dec 9, 2014
Shower & Bathtub Forum & Blog Roman Tub Faucet rough-in kit connection to water supply Aug 30, 2012
Shower & Bathtub Forum & Blog Water supply and pressure with Kohler Rite Temp valve. Oct 23, 2010
Shower & Bathtub Forum & Blog clawfoot tub water supply - flex? Sep 25, 2010
