Water Softener - Tankless
Discussion in 'HVAC Heating & Cooling' started by JohnO, Oct 12, 2007.
  1. JohnO
    JohnO New Member
    Nov 4, 2006
    New York
    Hi, do you need a water softener if you have hard water and want to install a tankless system? Another problem to deal with in deciding what system to go with. Thank you.
  2. jadnashua
    Think teakettle, then think about the huge quantity of water that goes through a WH. A tankless has higher spot temperatures, so deposits more than a tank type. It's a very good idea. Read the fine print about regular maintenance on tankless...sometimes, it can get quite involved or you start to get a dropoff in performance.
Similar Threads: Water Softener
HVAC Heating & Cooling Radiant heat and domestic water on same system? Feb 13, 2017
HVAC Heating & Cooling Indirect Hot water is Yellow Feb 8, 2017
HVAC Heating & Cooling Circulated hot water pros and cons Apr 10, 2016
HVAC Heating & Cooling Adding inline filter between water heater and humidifier? Nov 6, 2015
HVAC Heating & Cooling Hot water baseboard heater in basement - install Oct 11, 2015
