Water pump
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Randy54, Mar 25, 2013.
  1. Randy54
    Randy54 New Member
    Coatesville,Pa
    My pump comes on a lot with no water running. There are no leaks in the house. I'm told the most common problem is that the bladder loses air. I have a Gould model V60 . How can I find out the proper amount of air to put in. Thanks
  2. LLigetfa
    3,901
    NW Ontario, Canada
  3. cacher_chick
    3,244
    If the pump cycles when no water is being run, it is a sure sign of a leak. The leak can be anywhere between the pump and the fixtures in the house.
  4. valveman
    valveman Moderator Staff Member
    4,418
    Lubbock, Texas
    If you are sure no water is running then it is probably the check valve leaking back.
  5. Randy54
    Randy54 New Member
    Coatesville,Pa
    Thanks for the replies. Is the check valve on the line. Or on the pump itself?
  6. valveman
    4,418
    Lubbock, Texas
    Could be either or both. What kind of pump do you have, above ground jet pump or submersible?
  7. Randy54
    Randy54 New Member
    Coatesville,Pa
    Not sure of the make. Although I think it's a golds. It's sub
  8. cacher_chick
    3,244
    The pump has a check valve, and it is pretty common for he installer to place another in the drop pipe.
    It is also very possible that the drop pipe or lateral line is leaking, particularly if it is galvanized pipe.
  9. Randy54
    Randy54 New Member
    Coatesville,Pa
    It looks like the pitless adaptor is bad. Thanks for all the help. This site is very informative!
Similar Threads: Water pump
Pumps and Tanks Well Forum & Blog Water hammer while well is pumping Jun 18, 2014
Pumps and Tanks Well Forum & Blog Pull out water well pump Jun 2, 2014
Pumps and Tanks Well Forum & Blog Ejector Pump running in basement after water usage on main floor May 26, 2014
Pumps and Tanks Well Forum & Blog Lake water pump cracked housing - trying to determine best option with changed needs Apr 29, 2014
Pumps and Tanks Well Forum & Blog Do 200 feet of water above the 1.5 HP pump help the pump push 540 feet head up? Apr 17, 2014
