Water is leaking from the back of the dome nut. I replaced the ball assembly including the springs and two rubber o rings inside. I noticed that there is an o-ring behind the dome nut. Do you think this is the o ring that is causing the issues? I also didn't use any plumbers grease.
The only other thing I can think of is the plastic ring that screws into the top of the dome nut. I didn't have the Delta tool, so I hand tightened it and tried using a screw driver at an angle to screw it in tighter.
What do you think is causing the leak? It only leaks when the faucet is on.
