Water In Spurts.... Only When Pressure Switch On Start!?!?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by gswanjr1, Jan 4, 2008.
  1. gswanjr1
    gswanjr1 New Member
    Jan 3, 2008
    Hello.... I have recently had an issue with my well water coming into my home. I noticed that when I opened any of the faucets no water came out:mad:. So I went to the pressure switch and turned it from auto to start and water came rushing in. I would hold it on start until it filled up and the pressure was back to normal and things were fine. Well it would happen again almost minutes later & I would have to do this over and over again. Now & then I would turn it to start and get nothing, but most of the time it filled up with water. I noticed no leaks. But that if I continued to go and turn the pressure switch from auto to start, water normally comes in for as long as I hold start. I went out to the well to measure water levels with a string and weight attached to the bottom. I believe, the well from top of cap to bottom was 21ft (though not 100% sure- I never did it before), and that it was filled up to 10ft with water, and the other 11 ft were empty. I am not sure how far down the pump is... but I really need some help trying to troubleshoot and figure out what to do to get water to my wife and 2 children without getting a plumber I really dont have money for:confused:. But ANY help would be much appreciated :D, and thank you in advance!
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    If you did need help you wouldn't call a Plumber, you would call a Well Driller or a Pump Repairman.
    I think you have a low pressure cut off switch. It is designed to turn the pump off if the pressure gets to a certain point which is usually around 10 lbs less than your cut in pressure. You may have a waterlogged tank or your pump isn't doing as good as it once did. You could put in a standard switch and see if that cures the problem, but remember that switch may have been put there for a reason. Like a poorly performing well.
    bob...
  4. gswanjr1
    gswanjr1 New Member
    Jan 3, 2008
    Well Driller or Pump Repairman sounds even more expensive! But if I put a standard pressure switch... could that hurt anything (pump, tank, etc.)? But I have heard from others (here and there) how the wells have not performed well since a near highway was built....? Again, thanks.
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    That reminds me of an old joke:
    A man calls a Plumber out to fix his toilet. The Plumber installed a new toilet, gave the man a bill for $1500.00. The guy says "Damn, that's a lot of money to install a toilet, what do you think you are a Doctor charging rates like that?" The guy says "I was a Doctor until I discovered Plumbers made more money."
    Changing the Pressure Switch cold damage the pump if the Low Pressure Switch was installed because the well can't keep up with the pump.
    bob...
Similar Threads: Water Spurts
Pumps and Tanks Well Forum & Blog. Water is life. Acid Neutralizer/Water Softener Tuesday at 5:49 PM
Pumps and Tanks Well Forum & Blog. Water is life. Pump runs continuously while water is on. Mar 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wayne PC2 - Do I need a water strainer? Mar 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Remote cabin water problem Feb 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water Not Flowing Into House, Is It The Pump? Feb 24, 2017
