water in gas pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by shaggy, Feb 5, 2007.
  1. shaggy
    shaggy New Member
    Feb 5, 2007
    I have water in the gas pipes that lead to my pool heater. When I open the end, you can hear it bubbling. The heater won't work, I don't think it is getting enough pressure. Has anyone ever heard of this problem? Any ideas or solutions?
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Break the line apart where you got a union and blow it out with a compressor. The real question is how did you get water in a gas line? That needs to be solved ASAP.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    How do you know it is water?
  5. hj
    water
    Almost always when water is in a gas line, the pipe is rusted and has holes in it. Ground water around the pipe will almost always have more pressure than the 1/4 psi of the gas, so it can overcome it and enter the pipe. As you said, the gas does not have enough pressure to force its way through the water, or at least not enough volume, so you unit cannot work.
  6. shaggy
    shaggy New Member
    Feb 5, 2007
    The gas lines were put in about three years ago. We think that the water has gotten in from our old fire pit, which is elevated higher that the pool equipment. I used a wet vac and sucked out most of the water and I will install a drip leg. But now my pool gas valve is shot....just one thing after another.
  7. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Get the line blown out and re-test it with air and a good pressure gauge...
    If you cannot do it, hire a pro.
    Gas is something that you don't want to mess with if you are not comfortable...
  8. hj
    water
    It makes no difference how high, or low, the pool equipment is compared to the fire pit. If the line does not have holes in it the water could not enter the pipe, unless the valve was open and you poured the water into it. I assume you used the "approved" green coated pipe for the gas line. If so, that in my opinion, is the worst material you could possibly have used. I have seen installations that only lasted a few years and when it was pulled out of the ground it looked like swiss cheese.
Similar Threads: water pipes
Plumbing Forum, Professional & DIY Advice Need advice on repairs of copper pipes at water heater Nov 27, 2016
Plumbing Forum, Professional & DIY Advice Sewer Smell coming from pipes connected to hot water heater Nov 19, 2016
Plumbing Forum, Professional & DIY Advice Mold in water supply pipes Nov 13, 2016
Plumbing Forum, Professional & DIY Advice How to winterize water meter in open pit and street-side pipes Oct 28, 2016
Plumbing Forum, Professional & DIY Advice How to fix main water line leak issue-repipeing or rerouting pipes Oct 7, 2016
