Water Hammer - Shallow Well Suction Line
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Garyt, Sep 6, 2005.
  1. Garyt
    Garyt New Member
    Sep 6, 2005
    I have a shallow well pump in my basement that was previously connected to the well with about 80 feet of 1" plastic pipe. I recently replaced about 30' of this plastic pipe in the basement with 1" rigid copper to get it up off the floor. I now have a very loud and sharp water hammer when the pump shuts off. Previously the plastic would have a slap in it when the pump shut off. I only have a foot valve at the bottom of the well. I am considering putting in a Hydra-Rester in the suction line between the pump and the start of copper pipe. Will this work? Is there a better place to put it? Thanks.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I would look into changing the foot valve. If it still has the spring in it, there shouldn't be a hammer. I don't know what a hydrarester is, but it probably won't stop a hammer like that. I don't like check valves in the suction line for many reasons. And I don't know of any valve that was designed to go into a suction line to stop hammer.
    bob...
  4. Garyt
    Garyt New Member
    Sep 6, 2005
    The foot valve is not very old, maybe 4 years, and I was getting the plastic pipe slap when it was new. The Hydra-Rester is the name of the Sioux Chief Water Hammer Arrester. My problem seems to be when the copper pipe goes from being under suction to being under pressure after the pump stops.
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Was this new check valve a plastic valve or a brass valve. And do you remember the name of the valve?
    Are you certain there are no other valves in the suction line?
    With a working check valve there should be no slap when the pump shuts off, even with a high vacuum. The more vacuum and less water being pumped, the closer the poppet is to it's seat.
    bob...
  6. Garyt
    Garyt New Member
    Sep 6, 2005
    It was a brass valve, but I don't know the name. There are no other valves in the line. The line consists of a foot valve at the end of a rigid plastic pipe that is connected to about 40' of 1" flex plastic pipe that goes under ground to my basement. This line is then connected to about 40' of 1" rigid copper pipe that is connected to about 5' of 1" flex plastic pipe that connects to the pump. The output of the pump is connected to the pressure tank with 3/4" galvanised pipe.
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    You do have a mix of different piping there. But I can't explain the hammer without thinking the footvalve is bad. I don't know what else could be causing it. Changing pipe types shouldn't really have anything to do with water hammer.
    Although I don't like to do this, you could try to put a checkvalve in front of the pump. If the hammer goes away, you have fixed the problem. We'll never know why or how, but the hammer is still gone.
    bob...
  8. Garyt
    Garyt New Member
    Sep 6, 2005
    When you say put a check valve in front of pump, do you mean on the suction side or the pressure side? I would try and change the foot valve, but it is down in a well pit and not easy to do. What would be a good foot valve to use if I decide to try that? Thanks for your help.
  9. speedbump
    Jul 15, 2005
    Riverview, Fl.
    There are many brand names. I use Boshart's valve and love it. There are other's that are just as good. Stay with brass not plastic.
    bob...
  10. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I forgot to answer the other question. In the suction line always.
    bob...
  11. Garyt
    Garyt New Member
    Sep 6, 2005
    Bob, I tried the easiest fix first, which was to put a water hammer arrestor in the suction line at the well. This worked very well for about 6 cycles and then the arrestor failed. I guess it couldn't stand the vacuum. I then put a check valve in the suction line at the pump and that seems to be working great. Hope it continues and I think it will. Thanks for your help.
    Gary
  12. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I am not sure what a waterhammer arrester is for the suction line of a pump, but my advice is put as few fittings as possible in a suction line as possible.
    When you change the foot valve and remove the check valve, I think your problem will go away.
    bob...
Similar Threads: Water Hammer
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Water Hammer Nov 17, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well Water Hammer Aug 18, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Another Water Hammer Question Jul 10, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Water hammer while well is pumping Jun 18, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Will water hammer wreck jet pump? Nov 20, 2013
