I just hooked up a moen shower/spout combo and as soon as I turn on the cold water supply to the faucet, it comes out the spout. If I turn the faucet all the way, both ways, it doesn't change the flow at all. It is a very slow flow.
There is a good chance I did something wrong (well duh) but I thought I followed the directions.
I crimped the pex supply lines to a 1/2" nipple that is threaded on the opposite side and screwed them in the back of the faucet.
I used a copper pipe piece to drop down to the spout, attached with sharkbites.
The piece going to the showerhead is pex and is well secured.
I do not have any hot water going to this faucet yet. Could that cause this problem? Or regardless of having hot water, water should still not flow out?
If it isn't getting enough pressure, should this happen?
Someone told me that I should have put a small length of copper at the end of the supply lines and attached this length of copper to the faucet. Is this true?
I'd like to know what I should check out first. I thought I had all the ducks in a row!! Thanks.
