Washing Machine Connection Leak.
Alex
Hi there.
I am having a problem with the connection of my washing machine to the main water supply.
There is a small but constant dripping of water from the 'cold' connection.
This leak happens whether or not the machine is in use.
If I attempt to loosen the connection water begins to spray out in an alarming way.
It also continues when I turn the lever that is supposed to stop water overflowing when you dissconnect the machine.
I have been told that this could be due to a washer wearing out?
Can anyone help?
Apols if correct terms not used - Have attempted to attach a Word file which (if it works) could explain more clearly.
Thanks a lot
xx
  • Washing Machine leak.doc
