Freezing washing machine
Rsmith99
Oklahoma
We are going through about a week of 5 degree or less temperatures.
I have the heat turned up, space heaters running, and faucets dripping.
But my cold water line to my washing machine keeps freezing.
Is there a way to hook up the water lines so I could drip them? I don’t want to have to keep disconnecting them every night.
Thanks.
Eman85
Active Member
E TN
Is the line in an unheated area? Any insulation around it? If it's accessible you could try heat tape.
Rsmith99
Oklahoma
My house was replumbed in the attic. The washer is on an outside wall. The pipes have foam insulation and about 18” of blown insulation on top.
I just need a way to drip the faucets when not in use, but still be able to wash clothes when needed. Repeatedly disconnecting and reconnecting the lines can’t be good for the connections.
you mean like
Thanks.
You mean putting tees on the hoses and with valve andthen run garden hose to to a sink or floor drain? sure that works kinda hokey but if thats what you want entirely possible and easy to build. easy as pie!
Rsmith99
Oklahoma
Yes, it would kinda hokey. I guess a quick partial fill every couple of hours will have to do.
