venting thru eaves
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by doitmyself, Sep 26, 2004.
  1. doitmyself
    doitmyself New Member
    Sep 26, 2004
    I think code in NY state requires venting through the roof. Is it kosher to run the vent from the inside main stack, through the outside wall and up thru the eaves?
    Or is it a bad idea to run the vent where its most likely for an ice dam build-up (although, its on the south face of the house).
    Sched40 PVC ok for this type of application?
    thanks in advance.
  2. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    When I worked someplace that did not get much snow or cold, it was okay. In snow and/or cold country, it is not. We get alot of snow, but it does not generally get bitterly cold. I run all vents to the peak of the roof and never run a vent smaller than 2"--I prefer all 3".
    Deb
    The Pipewench
Similar Threads: venting thru
Plumbing Forum, Professional & DIY Advice Venting thru sidewall Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Wet venting WC thru lav in new basement 1/2 bath Feb 23, 2013
Plumbing Forum, Professional & DIY Advice Thru wall venting concern May 5, 2006
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Shower venting details/ dry run Feb 15, 2017
