Gary Slusser
That's all folks!
- Messages
- 6,921
- Reaction score
- 22
- Points
- 38
- Location
- Wherever I park the motorhome.
- Website
- www.qualitywaterassociates.com
What? You soak your gas tank in gasoline before draining out what you want to use to operate your car! Did you take out of it (the gas tank) the amount of gas you soak it (the gas tank) in? Was the tank full when you took the gas used to soak the tank in out of it? Or, did you use gas from another container? If so, do you mean you don't have a pickup or SUV?Does the fullness of your gas tank depend on the amount of gas it is soaked in before draining out the all the gas you will use to operate your car? Pretty sure the gas tank analogy is not valid . . .
What do you drain the gas into that you want to use to operate the car? What color is the car? watersolutions kinetico salesman Andy would probably want to know the color. Do you realize that your car's fuel mileage is controlled by your right foot; unless you have to have a hand operated throttle control?
Sorry, other than that, I'm pretty sure your question can only be interpreted by cartoonyguy Tommy. But then Lligfta or whatever might be able to surmise what you meant to say. Or was it F6Hawk? I think he's the one that surmises. LOL maybe water solutions Kinetico salesman Andy speaks your language. He'd probably want to know the HP and if it is a 4, 6, 8 or 10 cylinder engine too. OH yeah, and if you've recently correctly inflated your tires, or not. Ah yes.... DittoheadAlan... he might launch into the geometry of the steering, of both front wheel and rear wheel drive vehicles and especially truck tractors, and their exhaust systems, and get into the history of all those systems to end up telling you that you'll be satisfied with whatever you chose to do.
