Valves will not close
Discussion in 'Irrigation / Sprinkler Forum' started by mrpoune, Aug 12, 2007.
  1. mrpoune
    mrpoune New Member
    Aug 12, 2007
    Hi,
    This is my first experience with sprinkler systems.
    I am trying to install my electronic controller
    First, when the controller sends a signal to the valves (Orbit), is it normal to hear a big "TIC".
    Using the controller stations test feature, I have open the 3 valves I have. The run station of my controller (Rainbird) will not close them and now the only way to shut off the valve is to close the water. If I reopen the water then all the zones are activated.
    Please help
    Thanks
    Fred,
    Montreal, Canada.
  2. jimbo
    jimbo Plumber
    Controllers often have relays, which will 'click'. The valves will also click when activated. Generally, barring a massive short circuit, a controller doe not hold valves open. If they fail to close, that is usually a mechanical problem in the valve: stuck solenoid, or stuck diaphragm. You can confirm this by unplugging the controller. If the valves stay open, it IS a valve problem.
  4. mrpoune
    mrpoune New Member
    Aug 12, 2007
    Thanks for the quick reply...
    I managed to close the valves by hand by unmounting them. Now, it is working fine. something wrong with the initial valve position maybe... I did also remove a rock from the valve....
    Thanks
    Fred
  5. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Ahhh, an important detail. You want to leave those on the outside of the valves.
  6. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
    Any debris in a valve will cause a leak. Stuff as small as a grain of sand can cause a malfunction.
    Now then with your problem. Did you get all the valves to close and work properly every time?
Similar Threads: Valves close
Irrigation / Sprinkler Forum Severe water hammer/slow close valves Jul 12, 2005
Irrigation / Sprinkler Forum Possible top connect 2 valves in one zone? Jun 22, 2014
Irrigation / Sprinkler Forum Freeze Tolerant ball valves Feb 18, 2014
Irrigation / Sprinkler Forum automatic sprinkler valves May 1, 2013
Irrigation / Sprinkler Forum Hunter System Winterizing. Need some help with hookup. Valves not coming up Dec 2, 2012
