Use Sump Water For Toilet Flushing
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Porkus_Bellus, Apr 19, 2007.
  1. Porkus_Bellus
    Porkus_Bellus New Member
    Apr 19, 2007
    Retired
    Water has gotten very expensive in my area (sewer & rain water & "Clean River" charges are based on metered water use). Since I have clean ground water in my basement sump most of the year, wondering if I can take advantage of this free resource for toilet flushing & car washing.
    I would disconnect the toilet tank & outside faucet from the city water and run a separate line to the sump area. Then I would need a way to get the water out of the sump and into some kind of pressure tank. All the pumps I have looked at so far are very expensive and perhaps oversized for the job. I am experienced with electrical, copper, gas, and plastic piping but not wells or pumps.
    Is this project feasible or would it cost more than it's worth? Currently the sump has a submersible pump and the discharge goes to the street.
    Any suggestions or links welcome. Thanks!
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    You could be pumping that water into a cistern of maybe 300 to 500 gallons. Then pull from that with a jet pump to feed the toilet and hosebibbs. You will also need a bladder tank.
    bob...
  4. Porkus_Bellus
    Apr 19, 2007
    Retired
    :eek: Sticker Shock !!!
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Then you can keep paying that large water bill. The investment in the equipment I mentioned would save you a lot of money in a short time.
    bob...
  6. Porkus_Bellus
    Apr 19, 2007
    Retired
    Thanks to everyone for your helpful and intelligent suggestions. :cool: However, after having evaluated the cost vs benefit we have decided to build an out-house as a means of saving water. Please send your Sears catalogs and corn cobs. Thank You.
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Remember in the winter, always be the second one into the outhouse. That way the seat will be warm.
    bob...
  8. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    It might also help for everyone to bathe in the rain barrell on their ways back to the house ... and if you fit the top of it with a removable and fine screen, you will not have to deal with angry mosquitos while drying off again.
  9. jrseaberg
    jrseaberg New Member
    Dec 24, 2006
    manage a small business facility
    central IL
    stupid idea for solution???
    Recreational vehicles sometimes use a 12 volt demand pump. Some use a "pressure bladder tank" (don't know the correct name). This might work for refilling the toilets, but I don't think they have the pressure or flow capabilities for garden hose use.
    Jim
  10. hj
    sears
    As the farmer said when the sales person asked for the catalog number for the toilet paper he was ordering, "If I had the catalog, I wouldn't need the toilet paper."
  11. leejosepho
    Nov 23, 2006
    Something like that is probably even available in 110vac, and would easily work as suggested for re-filling a toilet tank. And, I believe the typical "pressure tank" for a small demand pump is simply a shock absorber to deal with water hammer.
    For washing the car, a slightly larger and still-inexpensive pump could be manually switched on or off and would not need a tank if a low-set PRV was serving as a CSV to keep it running for the duration.
  12. Porkus_Bellus
    Apr 19, 2007
    Retired
    Great idea - I'll look at the 12-volt RV stuff. I'd be happy just to take advantage of that clean sump water without getting a home improvement loan.
    This experience has taught me how important it is to have city utilities as well. Even though there are the assoicated utility bills, it's still less hassle than doing your own water testing, pumping/storage/treatment, sewage and needing a propane tank, etc.
Similar Threads: Sump Water
Pumps and Tanks Well Forum & Blog Sump Pump Water Hammer Nov 17, 2015
Pumps and Tanks Well Forum & Blog Water consumption by outpatients in hospitals and clinics Jan 5, 2015
Pumps and Tanks Well Forum & Blog Help: Worried too much water entering sump May 29, 2013
Pumps and Tanks Well Forum & Blog Softened water into sump pump well? Dec 10, 2011
Pumps and Tanks Well Forum & Blog Sump pump cycles discharged water - Help! Sep 30, 2011
