Urgent-No Hot Water
Discussion in 'Tankless Water Heater Forum' started by rbeny10, Mar 3, 2012.
  1. rbeny10
    rbeny10 New Member
    Feb 29, 2012
    Israel
    :mad:1. The following sittuation is for 2 WK,so pls' HELP,before I'm thrown out with the Water Heater.
    2. Tech. details :
    - TYPE: WT14, by JUNKERS ,Model-2005(Wasn't used all the time=>looks new!!!)).
    - It works on Butane Gas (E31 Sub-model.
    - Its full automatic.
    -The problem: After a couple of min. of work, It shuts-down automatclly.No hot water.RED bulb lightens.
    -Suspichious: Becouse,while working,the temp. increases without limit, possiibly: The security cut-off circuit is provoked ,becouse of excesive temp.
    -Diagnostics done: a) Checking the resistance of the Temp variring Potentiometer (in front of the Heater panel), couses NO RESISTANCE CHANGE(constant 16Koham)!!???Since I dont't have the schem. I can't conclude if its a bug!.
    b) Chek of HOT WATER NTC RESIS.: I'm confident its O.K.
    c)Check Voltage of Temperature Limiter /Temp. control (Both names appear in the Appliance Spec.),showes :4mv while the Heater works,dropping to 0v(absolute zero),when jumping into cut-off.
    d)Check of Presostat: O.K.
    e)Visual and Sut-down tests: O.K.
    f)Gas pressure:O.K (gange of old central gas flow cont,from 7liter/Hr to 10 liter/Hr)
    My conclutions:1.The heater jumps into cut-off,bec. the hot water regulation circuit mailfunctions.
    The most suspicious circ. is the "Temp. control/limiter (i.e:4mv doesn'tlook to be normal,for correcr operation!???)
    2.The heat varing pot.malefunction: EVENTHOUGH THE bar shaft turens freely,mybe (but with 1% choice)its mechanicaly dissconnected gr. the pot. inner shaft=> doesn't affect it??.
    3.Any type of support(i.e.: Any schematics/Manual will be sized up.
    4. Any type of self experiance(even from other Gas Water heaters) will be sized up.
    5.Regarding the Manufecturer: So far I find-out the foll. link to Turkich dealer,but,he didn't reply to my mail!!
    :http://www.bosch.com.tr/content/language2/html/5232.htm
    Thanks-Beny
Similar Threads: Urgent-No Water
Tankless Water Heater Forum New to tankless water heater and can't figure it out! Mar 16, 2017
Tankless Water Heater Forum Tankless Water Heater Cleaning Solution? Mar 7, 2017
Tankless Water Heater Forum Descaling a tankless water heater Mar 4, 2017
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Rheem water heater need trouble shooting. Jan 14, 2017
