Two Wells on one Jet pump?
Two on one pump possible?
  • Possible
    Votes: 0 0.0%
  • Doubtful
    Votes: 0 0.0%
  • Impossible
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Jeff Young
State College, PA
I think it's possible...
I had asked a couple people on this idea... A tee at the pump, a valve on each intake, and two wells attached to one jet pump.
Well 1 is hand-dug. Low recovery rate
Well 2 is 60 feet. Neighbors have insufficient water to do laundry on our block. Hoping to get water from both.
I had just switched the intake from poly pipe. It goes
1" poly pipe to poly valve... To poly pipe to IP connector.. to galvy elbow... To check valve (arrow pointing up).. to tee.
Top side of tee is with the valve off.
I don't get air like I was before but I also don't get any water pressure. I tested the pump by putting water in the high valve and it sucks immediately. Some pressure builds inside the pump but nothing useful.
I have valves to switch manually from one well to the other...
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You can draw from two wells. But the pump needs to be the high spot in both suction lines. That line coming in from above will never get the air out and you will lose prime.
I think it would be important to not suck air from either.
You cannot draw water reliably from lower than about 25 ft down with suction.
Maybe have a separate horizontal submersible pump, with a flow inducer shroud, in the dug well, and have a float switch down there that controls a relay. The relay decides which pump turns on.
