I have installed new tub and now need to replace the existing brass trap since it does not line up with new tub drain and it is not adjustable. The Plumber is recommending PVC trap tied into the existing copper drain line. Is this my best option? If so, should this new PVC be all glue joints, are compression fitting allowed for under floor installations?
Any information would be greatly appreciated. I don't mind PVC, but want to make sure it is installed properly.
Thank you.
Thank you.
