Tub Spout Diverter Dilemma
Discussion in 'Shower & Bathtub Forum & Blog' started by Hawaiianguy, Apr 19, 2013.
  1. Hawaiianguy
    Hawaiianguy New Member
    Apr 19, 2013
    Hawaii
    Aloha!
    I'm trying to shop online for a new tub spout with diverter. The old one was leaking around the diverter pull up knob, also there was a 1/4 inch gap between the wall and end of the spout which looks to be filled with calking.
    I'd like to find a new tub spout that will screw on the existing 1/2 male threaded copper pipe. From the wall to the end of pipe looks to be 4 5/16 inch. The old spout looks to be 5 1/4 inch.
    Can anyone suggest a model that would work with this plumbing setup without me having to any major reworking on the pipe end?
    Thanks in advance!
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    There are tub spouts that just slip on. All you would have to do is cut the copper pipe off behind the fitting, clean the copper. Most are held in place with an allen screw. Most big box stores will have them.
    John
  4. Hawaiianguy
    Apr 19, 2013
    Hawaii
    That would only leave about 3 inches of pipe if I cut it off behind the fitting. Is that enough pipe to slip a new tub spout on. If so, any recommendations on a tub spout diverter that would work. I like good quality products that last.
  5. hj
    quote; I like good quality products that last.
    Few tub spouts, especially the ones you are looking for qualify for that description. Normally, if you find a spout with the thread "at the front" and a pull up diverter, it will have the same dimensions as your old one. Slip on spouts only need a couple of inches of copper out of the wall.
  6. Hawaiianguy
    Apr 19, 2013
    Hawaii
  7. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    That one screws on. There is a good chance that it will be too short or too long for your setup. The one you need is the Moen slip spout on the same page.
    John
  8. jadnashua
    I much prefer something like the Delta with the pull-down diverter, but it would require a different soldered on adapter.
  9. hj
    That one "should" work, but you would have to measure its depth to the thread to be sure.
  10. Hawaiianguy
    Apr 19, 2013
    Hawaii
    Thanks everyone and Terry for editing my post & providing the Delta website which showed the installation instructions w/ measurements. Might need to take off a few fractions off the male end to make it work but looks like a doer.
Similar Threads: Spout Diverter
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Is this Grohe leaky tub spout diverter repairable?? Jan 2, 2017
Shower & Bathtub Forum & Blog Slip-on tub spout w/ diverter recommendation? Sep 20, 2016
Shower & Bathtub Forum & Blog Water comes out from shower diverter spout May 23, 2016
Shower & Bathtub Forum & Blog How does shower line drain through tub spout when valve is off and diverter is set to tub? Apr 3, 2016
