rssahlman
I just installed a new cast iron tub....I used new PVC parts for the drain connections to the existing pvc trap. I seemed to have a leak where the drain meets the tub drain (the tub shoe). The new drain had a rubber gasket and I used both plunbers putty under the brass drain(in bathtub) and Teflon thread dope. Can you tighten the drain too much?? Any suggestions why this might be leaking....all other connections are pvc compression fittings that are fine.
