Tub Drain Test Plug?
Discussion in 'Shower & Bathtub Forum & Blog' started by jw123, Aug 11, 2008.
  1. jw123
    jw123 New Member
    Aug 11, 2008
    Howdy y'all. First time posting, so thanks in advance.
    I'm installing a new tub in a home addition. I've been assured that the local codes inspector wants to see at least 42" of water in a standpipe (above the washer box) and the bathtub filled above the overflow. I've got a plug in a test tee down stream of the new bathroom that will fulfill requirement #1, but short of disconnecting the tub drain assembly from the PVC drain line, I can't see how I could do both at the same time. Is there a device (or something integral to my tub drain assembly) that will plug my tub drain and overflow?
  2. Master Plumber 101
    Master Plumber 101 In the Trades
    Aug 11, 2008
    Wisconsin
    I don't why your inspector wants water above your overflow to test the rest of the drain piping. I would suggest disconnecting trap and putting a fernco cap on the drain line to the tub. Test out waste and overflow later by plugging tub until water goes into overflow.
  4. hj
    test
    There are tub drain test kits which have screw on covers for both the overflow and tub strainer.
Similar Threads: Drain Test
Shower & Bathtub Forum & Blog Testing Shower Drains for Compatibility with Wheelchair Use Nov 24, 2013
Shower & Bathtub Forum & Blog How to leak test tub drain? Mar 18, 2007
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Monday at 10:06 AM
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
