AndrewKR
The soda ash pump was continuously running after the water was shut off. I found the flow switch control that activated the soda ash pump and learned to push the plunger down to manually turn the pump off when no water was flowing. The pump would correctly start when water flowed but would not shut off when water was shut off. I played with the set screw in the flow switch control but could not get it to work correctly. It would get stuck in the on position. I convinced myself the flow switch was malfunctioning and replaced the flow switch with a new one of the same model. Unfortunately, I'm getting the same symptoms with the new flow switch in place. Something else is happening here, but I am at a loss.
I'll add that this all started two weeks ago when we had a leak in our water well pump. Water was pouring out from the wire harness conduit from the well pump into our crawl space. The well service excavated 6 feet to where the harness meets the well pump and replaced the seal. He also replaced our well water tank (it was rusting and 20 years old) and said we should see slightly better water pressure, which we did. After that issue was resolved, we started having the soda ash pump issue described above.
Attached are a few pictures
- Soda ash Pump
- Flow Meter
- Softner Controls (just so you see the gear we have if it's relevant)
What next steps should I take to troubleshoot this?
Thanks for your help!!
- Soda ash Pump
- Flow Meter
