troubleshooting a electric water heater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Peevee, Jan 3, 2007.
  1. Peevee
    Peevee Member
    Oct 24, 2006
    Milan, Tennessee
    On a electric 240 volt water heater how can you tell if a element is burned out or if it's a thermostat. Also what should the voltage check at the elements? Thanks:)
  2. hj
    heater
    Are you competent to work on it with the power on? If so, then a voltmeter to the terminals to see if it has power to the element, and then a clamp around ammeter to see if it is drawing any power.
Similar Threads: troubleshooting electric
Plumbing Forum, Professional & DIY Advice low water pressure troubleshooting May 25, 2016
Plumbing Forum, Professional & DIY Advice Help troubleshooting hot water running out quickly (replaced dip tube already). Nov 26, 2015
Plumbing Forum, Professional & DIY Advice Evaporative Cooler Thermostat Troubleshooting Jun 10, 2015
Plumbing Forum, Professional & DIY Advice Mixing Valve Troubleshooting? Dec 29, 2014
Plumbing Forum, Professional & DIY Advice Troubleshooting - Expansion tank or PRV? Dec 24, 2013
