Trouble Flushing Navian NCB primary heat exchenger
Amir Eyal
Royal Oak, Michigan
Hi everyone, I have a Navian NCB 240 combi boiler with a Navian Primary Secondary Manifold. I was able to flush the domestic Hot water heat exchenger with no issue using a pump, 5 gallon bucket and 2 hoses. I am having no luck when trying to flush the primary heat exchenger.
I made sure the service ports on the Manifold were open by turning the screws half a turn and connected the two hoses to the ports. When I turn the pump on there was no flow through the heat exchenger as if some valve was closed and not letting the water circulate.
Does the 3 way valve have to be in the position of the primary heat exchenger to flush it? How do I manually do that? Am I missing something else? Thanks for the help!
Fitter30
Peace valley missouri
Only the dhw side would get limed up the boiler side should stay clean as the water just recirculates.
Amir Eyal
Royal Oak, Michigan
Thanks fitter30, I called Navian and they suggested flushing the primary heat exchenger once a year. I saw the video you posted a link to. I did exactly what was shown there and was unable to get water flowing through the primary heat exchenger. It's interesting to see that someone commented on the video and asked if you should call for heat before flushing to change the position of the 3 way valve. I will give that a shot.
