Toto Leaky Fill Valve
Discussion in 'Toilet Forum discussions' started by wtreedy, Dec 8, 2006.
  1. wtreedy
    wtreedy New Member
    Dec 8, 2006
    I recently installed a Toto UltraMax toilet. The toilet works fine. However, the fill valve starts to leak after a week or so. It will shut the water off at the appropriate level. Then a slow leak will occur and the water level will slowly rise until it leaks into the overflow tube after 10 to 15 minutes. I have replaced the fill valve twice, but all three fill valves have this problem. The problem does not begin until the fill valve has been in the toilet for more than a week. I have tried to adjust the height level ever so slightly, but this does not stop the leak.
    What is the problem?
    How do I fix it?
    Thanks.
  2. jadnashua
    Are you on a well? You might have crud (sand, etc.) that is getting into the gasket. You can replace the cap which contains the seal for about $2, and while you have it off, check it for crud.
    Instructions here
    These valves work fine with any legal water pressure.
    Anything over 80 PSI needs a pressure reducer.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    You might want to try a different brand of fill valve. Could be your water pressure is too high for this one.
Similar Threads: Toto Leaky
Toilet Forum discussions Toto CST744S with a leaky valve - help! Jun 14, 2014
Toilet Forum discussions Toto Ultramax Leaky fill Valve Oct 13, 2010
Toilet Forum discussions Leaky Toto Carlisle Toilet (Something is Wrong!) Jan 13, 2008
Toilet Forum discussions Toto - Leaky GMAX fill valve Jul 4, 2007
Toilet Forum discussions Leaky fill valve on Toto Drake I just installed May 10, 2007
