Ove toilet fill valve
discogodfather
Ontario
A contractor replaced our toilet recently with an Ove dual flush model and the fill valve always seems to be hissing. I'm not sure what model the toilet is, but the fill valve resembles the one in this YouTube video.
A few questions:
1) The hissing stops when I shut off the water line to the toilet. Does this mean the hissing sound is the toilet trying to draw in more water (and thereby racking up a water bill in the process?)
2) Would adjusting the fill valve potentially stop this issue?
3) Has anyone tried adjusting this type of fill valve without removing it from the toilet? I'm very mechanically UNinclined and am not comfortable removing the fill valve.
Any help is appreciated!
John Gayewski
Iowa
There's probably a way to clean it if you look up the brand and model. Not sure about these as I haven't had to fix one, but I'm sure it's simple.
How high is the water in the tank with respect to the top of the overflow?
discogodfather
Ontario
John G., I'm not sure if it's a cleaning issue as the toilet is brand new. Reach4, the water level is about 1.5 inches below the top of the overflow tube. I've attached a photo. While taking the photo, I just noticed the words "water line" near the top of the overlow tube. The water level is definitely below that line.
discogodfather
Ontario
Here’s some more info. Last night I closed the valve that provides water to the toilet. This morning the tank was nearly empty.
Informative. We can eliminate several things as causes.
Some flush towers have a replacable seal. I would call the maker or seller of your toilet, and ask about a tower flush seal.
