Toto Fill Valve Problem Continues G-Max valve with adjusting screw
Discussion in 'Toilet Forum discussions' started by levitonski, Nov 30, 2008.
  1. levitonski
    levitonski New Member
    Nov 30, 2008
    After reading the good Toto reviews I replaced 4 toilets with them. Well the problem with dribbling fill valves that was covered on this forum last year, is still continuing. I have the G-Max valve with adjusting screw and they are leaking like your earlier reports. This is the end of 2008 and I'm angry that these toilets are still being sold with defective fill valves. The leak is quiet and I've just discovered it after 6 mo. of loosing water.
    David
  2. pmccarten
    pmccarten New Member
    Dec 2, 2008
    Response?
    Hi David,
    Did you ever receive any responses to your thread? I'm having a similar issue and am pretty frustrated. Can you point me in the direction of the thread from last year you referred to, re: "dribbling fill valves"?
    Pat
  4. levitonski
    Nov 30, 2008
    Pat
    I contacted Toto Customer Service and was told they have redesigned the fill valve. They are sending replacements to me. Hope this helps.
    David
    One thing to check if it's not shutting off is the pull-out screen at the inlet of the valve.
    [​IMG]
Similar Threads: Toto Fill
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Toto CST416 refill is not consistent flow Jan 9, 2017
Toilet Forum discussions Fill valve for Toto ST701 Aug 20, 2016
Toilet Forum discussions Toto Promenade Fill Valve 2016? Jul 26, 2016
Toilet Forum discussions TOTO Drake II fill valve adjustment Apr 18, 2016
