I have installed many toilets over the years, but this one has me a little confused. This is a 1 piece model, with a plastic offset P-Trap, that connects the toilete to the lead / brass flange on the floor. I connected the Plastic offset (P-TRAP) to the brass flange, obviously with a wax seal, tightened the bolts. After I slipped on the toilet, when I flush, it leaks a very small amount of water on the right side, not the left. I removed the toilet and left the PVC-TRAP connected to the brass flange, and poured water through the PVC-TRAP myself, no leaks. Slipped the toilet back into the PVC trap, leaked again, "ONLY" on the right side. The PVC offset / P-trap has not been drilled into the tile, but with the tightening of the brass flange bolts, it doesn't move either. Is it possible, that the cermaic tile is uneven, causing the toilete to not slip in properly into the plastic PVC trap, causing the leak "or" do I have a defective toilete?
It is impossible to look at exactly where the leak is coming from against the plastic offset, given the limited amount of space....Perhaps I can put a little mirror there or a ridgid mini camera, but has anyone seen this issue with these types of toilets because I would like to know what I am looking for
Thoughts appreciated
