Too much staining from iron in well water
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Golfsupttdd, Sep 2, 2008.
  1. Golfsupttdd
    Golfsupttdd New Member
    Sep 2, 2008
    Any recommendations on types/brands of system to inject a deionizing solution with my irrigation water?????????
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    We sell a chemical that is manufactured here in Florida that is mixed with water depending on your water's mineral make up that when injected with a chemical feed pump will sequester the iron and make it fall off instead of staining.
    bob...
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Here is a link to managing iron and manganese in drinking water. Some of it may apply to your irrigation application.
    http://www.fs.fed.us/eng/pubs/html/99711308/99711308.html#Seque
    Sequestration is reported to work at iron concentrations up to 3 mg/liter.
    If you have a large area you could set up a settling tank (a pond), or an open-air sand filter to filter the water after it is oxidized. It would require re-pumping.
Similar Threads: much staining
Pumps and Tanks Well Forum & Blog. Water is life. New Well - How much gpm should I need? Jul 22, 2016
Pumps and Tanks Well Forum & Blog. Water is life. How much water drawn before pump cuts on Jun 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Output Dropped Way Off How Much To Lower Well Pump? Apr 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. How is so much air getting into our water system? Mar 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Circulating well with too much water May 8, 2015
