Quack
Hello everyone.
I have 2 questions which may or may not be related.
1.) I think my water pressure regulator is faulty. If I screw in a water pressure test gauge into a garden hose outlet, and leave no other faucets open, it reads about 95-100 psi. However, when I open a valve inside (just a slight crack), it goes to 50 psi. In addition, if I turn on the kitchen sink faucet, initially the water comes out really, really fast, but then noticeably slows down. As soon as I stop all the faucets, the pressure returns (almost immediately) to 95-100 psi. I have city water.
Is my water pressure regulator faulty? I don't think I have an expansion tank, so I don't know if I should add one first. The pipes are all buried, so I'd guess they would be at a relatively constant temperature. I have tried turning the adjustment screw to lower the pressure, but then the running pressure is way too low. Is it normal that the static and moving water pressure would be so far apart?
2.) I have a Fleck 5600 SXT water softener. I've had 2 leaking issues. Both times, the turbine meter assembly (a cheaply made, but ungodly expensive part) has broken. Here's a picture of it. What would cause this part to start leaking after only 1 month in use. Would having a static water pressure of 90 psi do it? I figure you would need much higher psi's for it to fail.
