toilets not in use
Discussion in 'Toilet Forum discussions' started by jjack67, Sep 25, 2011.
  1. jjack67
    jjack67 New Member
    Sep 25, 2011
    austin, tx.
    We need to replace 2 toilets in our second home. They sometimes are not in use from 1 to 6 months. Are there any toilets that work or don't work that can sit for this period of time not in use. We now alway turn the water off, make sure water is left in the bowl and tank before we leave. Code in our area is 1.6. Have replaced 3 toilets in our main house with Toto, outstanding, but were hoping to save money on going with a less expensive one at our second home due to lack of use.
    Suggestions?
    Thanks,
    JJ
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Personally, I think this is false economy, but it's your call. The Big Box Stores have tons of cheap toilets they would be glad to sell you, some for as little as $100 complete. You never know for sure, you might pick one that works just fine for your needs, but you might also pick a dog. If you leave this place in the winter, you need to winterize the plumbing. That would include RV antifreeze in the toilet trap and at least draining the P traps elsewhere. The water lines should be blown out. A plumber could probably design a system for blowing the lines that would be fairly easy, but would require an air compressor. Once designed and installed the winterizing would not take too long or be too costly. I would take a second look at the Eco Drake for replacement toilets. 1.2 gpf and top performer.
  4. jadnashua
    Austin's sort of on the edge...hot, but sometimes humid, unlike the 'norm' of western TX. Any water can evaporate and if it does, it opens up that fixture to the sewer (or in your case, probably a septic system). Some toilets have a larger water spot than others, but they all can evaporate dry overtime. Maybe some plastic wrap over the top would prevent that. Any trap can evaporate dry. It won't hurt the toilet, but the first time you go to use it, you may want to flush once first - this will refill the bowl to the proper level so it has its best chance of actually working.
  5. jjack67
    jjack67 New Member
    Sep 25, 2011
    austin, tx.
    Sorry, folks , forgot to mention this is a condo, so having to winterize is not an issue.
    Thanks for your suggestions.
    And, yes, I think you maybe right in regards to false economy but thought it was worth checking
    Thanks, again
    JJ
Similar Threads: toilets
Toilet Forum discussions Older toilets are gold! Jan 13, 2017
Toilet Forum discussions Wall mount toilets- fastening systems Jan 9, 2017
Toilet Forum discussions How toilets work - holding the handle down for more water Nov 14, 2016
Toilet Forum discussions Products to clean Toto toilets Sep 3, 2016
Toilet Forum discussions Re-route of back-to-back toilets to new sewer hook-up Sep 1, 2016
