I live in a condo, on the top floor.
A few days ago, the condo unit below mine reported that a small amount of water had leaked through their ceiling heater in the bathroom. This only happened on one day and has not happened since. The day this occurred, I do not recall any spills or overflows from my unit.
Since this only happened once, I don’t think it is a leak in a pipe or anything.
My suspicion is the toilet. I have been needing to replace the whole mechanism in the toilet tank (the plastic unit that monitors the water level), as the tank takes a while to start filling after a flush. Plus, the flange in the tank sometimes doesn’t flop to cover the hole unless I shake the handle. Both annoying, but I didn’t think they were causing issues.
The day the leak occurred for my downstairs neighbor, I remember coming home and realizing that the toilet had been running all day while I was at work. I didn’t think this would cause any issues and that the excess water would just go down the pipe. Is this a false understanding? Is it possible that water is leaking out, somehow, and instead of going down the sewage pipe it is leaking around and down to the unit below?
I plan on trying to replace both the wax rings and the tank mechanism. Any thoughts on if this will possibly solve the problem?
Thanks for any advice anyone might have. Clearly I have little plumbing knowledge.
