Hello,
I have a 1 yr old home with a pvc toilet flange on tile floor. A couple weeks ago, I cracked the flange by tightening down too tight on the toilet. Not to worry... I found a stainless steel metal flange repair ring at the hardware store. A couple of the original screw holes already seemed stripped, but I have I believe 4 screws connecting the repair ring to the original flange. While screwing one in, I heard a slight crack. Had drilled pilot holes for my own screws because repair ring holes didn't all match up. Don't see any new crack other than the first crack on the opposite side of flange (where closet bolts attach) seemed to be a little worse. Seems pretty stable. While repairing, the flange appeared to lift up slightly, so I pushed it back down and haven't had it move since, even when I tried pulling up on it. Weird, since it appears to be threaded and glued inside another pipe, but kinda hard to tell for sure. Not sure what flange screws are going into, if anything. If I don't see any visible cracks inside the pipe or on/in the flange other than the closet bolt area of the original flange, should I just leave well enough alone and not worry about it? I used a new wax ring with the funnel on it and put the toilet back down.
Thanks to anyone with advice.
