bfox4546
We are in a house built in 1956. Recently the toilet and shower in the master bedroom started to drain slower. Then the toilet backed up. Assuming a clog I used a plunger on the toilet. While plunging I see water coming out from under the toilet. I pulled the carpet back and the plywood floor was wet and looked rotted around the toilet.
I'm in the process of replacing the floor. Also going to replace the toilet. The problem I've run into is a 10" lead pipe riser attached to the toilet flange. I would appreciate knowing the correct way to remove the riser and what to replace it with.
I replaced the water lines in this house and also put in a new shower. All with no problems. I also do plenty of air and water lines at work. However, I have not done toilet replacement. I need to do this right so I don't get to do it twice. Thank you for your time. Bob in Amarillo.
