Toilet flange extender
Discussion in 'Toilet Forum discussions' started by dmack43, Mar 6, 2012.
  1. dmack43
    dmack43 New Member
    May 4, 2009
    Gents,
    A new tile floor has resulted in a finished surface 3/4 of an inch above the existing 4" cast iron flange which is seated in the concrete slab floor. The inside of the cast iron pipe - where it is level with the flange - is slightly irregular (lead?) and may make it difficult to insert a rubber gasket in to the 4" pipe. I plan on installing a new low flow toilet and would appreciate advice on selecting an extender and gasket.
    dmm
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Sioux Chief makes flange extenders in both 1/4 and 7/16 thicknesses, either of which can be stacked to create the desired thickness. The extenders go on top of the existing flange- there is no gasket.
  4. hj
    Besure to seal between the flange and extender(s), and secure the extenders because plastic has a tendency to "warp" over time if it is not firmly anchored.
  5. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    Yes, and that's in the instructions for the Sioux Chief extenders as well (printed on the ring.) Don't let the big box store former "plumbers" talk you out of this sealing step by telling you, "I never do that."
Similar Threads: Toilet flange
Toilet Forum discussions Push in toilet flange Mar 14, 2017
Toilet Forum discussions Toilet Flange not Flat/Level Feb 21, 2017
Toilet Forum discussions Odd Offset Toilet Flange Dec 21, 2016
Toilet Forum discussions Toilet Flange Height on New Tile Dec 19, 2016
Toilet Forum discussions Toilet flange question Dec 7, 2016
