Sincraft
Greetings all, first time poster...long time lurker..
Please excuse me if this has been posted before, I searched but somehow didn't hit my situation.
My project:
I am remodeling a powder room. Completely gutted everything, including the walls. Redrywalled everything, painted (one more coat to go on walls), but before I wainescot, I have to set my MARBLE tile because a baseboard has to go in first (slotted) that will hold the wainescot slats.
I have a completely bare subfloor, that I preped and secured any and all questionable nails with 3 inch screws.
My problem:
1.My old closet flange sitting on the subfloor is rusty. Not completely, but bad enough that the bolts would rip right through if used again.
Home depot plumber guys told me to use this metal disc/star thingy that has screw holes outside of the perimeter of the normal closet flange.
Is this the way to do this? The old closet flange (the plastic part) is seemingly cemented to the actual waste pipe, I tried to pry...jimmy..turn , but it's all connected.
2.Another problem I have is that I will have to be very careful with my HARDIBACKER to come as close to and around these points and up to the old flange so that I can tile as close to this as possible , otherwise my toilet will show lines from the tile.
3 MY BIGGEST issue is, after the first layer of cement, then 1/2 hardibacker, then more cement, then my 3/8 tile, I will be probably an 1"+ off of the floor! The top of the flange is only 3/8"heavy tops.
Suggestions PLEASE!
S
My project:
My problem:
Suggestions PLEASE!
S
